19-11-2020 #1
Do you have those moments when you think you have done something neat, and then you realise it really was a bit stupid?
I had a stepper motor with a 5mm shaft and a coupler with a 6mm hole. I got a piece of 6mm brass rod on the lathe and drilled it 5mm to make a tube shim. the other shaft is 6mm anyway and when I tried it on the coupler I realised it was a 6mm to 1/4" converter, so I got a piece of 8mm brass rod and turned it to 6.35mm and drilled it 6mm, making a delicate tube with a wall thickness of 0.17mm.
I was pleased with that, then I thought - Ey up, why did I not just stick the 6mm shaft in the 6mm 'ole and make just one quarter to 5mm adapter - Doh 🤦*♂️🤦*♂️
Cheers,
Rob
(getting older, getting fatter and getting stupider)
Rob.
Join the club
19-11-2020 #3
It's the "when the cat has kittens you have to add another, smaller, cat flap" syndrome.
It happens - and increasingly often for some of us...
Losing steps/position, again
By ngwagwa in forum Artsoft Mach (3 & 4)Replies: 137Last Post: 30-04-2020, 12:23 PM -
Losing steps
By Edendale in forum General DiscussionReplies: 11Last Post: 06-03-2020, 10:10 PM -
Losing steps on Z axis
By Arzo10 in forum Machine DiscussionReplies: 15Last Post: 31-03-2017, 10:49 AM -
New Mill losing steps
By lukecnc2012 in forum Gantry/Router Machines & BuildingReplies: 42Last Post: 08-11-2014, 02:56 PM -
x-axis on Orac losing direction
By asto in forum Motor Drivers & ControllersReplies: 3Last Post: 29-03-2013, 01:22 AM
