    Do you have those moments when you think you have done something neat, and then you realise it really was a bit stupid?
    I had a stepper motor with a 5mm shaft and a coupler with a 6mm hole. I got a piece of 6mm brass rod on the lathe and drilled it 5mm to make a tube shim. the other shaft is 6mm anyway and when I tried it on the coupler I realised it was a 6mm to 1/4" converter, so I got a piece of 8mm brass rod and turned it to 6.35mm and drilled it 6mm, making a delicate tube with a wall thickness of 0.17mm.
    I was pleased with that, then I thought - Ey up, why did I not just stick the 6mm shaft in the 6mm 'ole and make just one quarter to 5mm adapter - Doh 🤦*♂️🤦*♂️
    Cheers,
    Rob
    (getting older, getting fatter and getting stupider)
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Rob.
    Join the club
    It's the "when the cat has kittens you have to add another, smaller, cat flap" syndrome.
    It happens - and increasingly often for some of us...
  1. Losing steps/position, again
    By ngwagwa in forum Artsoft Mach (3 & 4)
    Last Post: 30-04-2020, 12:23 PM
  2. Losing steps
    By Edendale in forum General Discussion
    Last Post: 06-03-2020, 10:10 PM
  3. Losing steps on Z axis
    By Arzo10 in forum Machine Discussion
    Last Post: 31-03-2017, 10:49 AM
  4. New Mill losing steps
    By lukecnc2012 in forum Gantry/Router Machines & Building
    Last Post: 08-11-2014, 02:56 PM
  5. x-axis on Orac losing direction
    By asto in forum Motor Drivers & Controllers
    Last Post: 29-03-2013, 01:22 AM
