Thread: Spindle not running - Need Help
I'm cautious about offering any advice here, because I fear this could run and run and go nowhere, and you're rather too far away for me to eyeball.
Has the spindle operated in the past?, i.e. is this a newly developed problem, or not? - that'd help us to understand a starting point.
You show an image of the VFD commanding a forward rotation at 400Hz (typically 24k rpm for a 2-pole spindle) - but the spindle doesn't rotate?, that's an alarm bell to me - irrespective of the behaviour of the flashing light on the USB BoB - if the VFD is commanding rotation and the spindle isn't moving, I'd be worried about either the VFD or the spindle. However, I'd expect the VFD to display a fault in either case.
Edit: https://www.automationtechnologiesin...l-v1.17-EN.pdf looks to refer to a similar BoB, with a statement "Status indicator LED can be useful to show the USB connection, and working status by flashing."Last edited by Doddy; 22-11-2020 at 11:11 AM.
Need Help! Spindle not running
By Lumiyo Ben in forum Spindles & Drive MotorsReplies: 0Last Post: 21-11-2020, 03:11 PM -
Running 4 1605 screws
By kev20009 in forum Lead Screws, Nuts & SupportsReplies: 13Last Post: 22-02-2017, 10:33 PM -
Getting my Arburg c4 up and running
By deadmeat30 in forum Moulding MachinesReplies: 4Last Post: 30-11-2015, 09:54 PM -
Advice on running YAG laser in UK
By chriggy in forum Laser Machines & BuildingReplies: 0Last Post: 09-02-2015, 02:29 PM -
Running costs of CNC machines?
By .kyle in forum General DiscussionReplies: 1Last Post: 19-05-2011, 08:05 PM
