So, assuming you're running Mach3, can you enter an MDI command "M3 S18000" and the VFD (the black box connected to the spindle with the red 7-segment display) will display "F300.0" and indicate the "For" LED?, and the Spindle still refuses to spin?
I have entered the code into mach3. the spindle speed bar is flashing yellow which happens when the spindle is moving.
The code on the VFD is showing A0000
ID:	29181Click image for larger version.
Thanks again for your help with this
Cheers Ben
