Thread: F369 "rapids" plugin
22-11-2020 #1
Can someone possibly assist my ever-failing memory? I'm sure that I read somewhere in the last couple of weeks or so that someone has developed a F360 plugin that is designed to overcome the "rapids at G1 speed" constraint in the new free version. It either rewrites or intercepts and modifies the code so that expected G0 rapid feeds are restored. However, I dip in and out of various forums and I can't remember where I saw that one. Has anyone else seen that?
I'm sure that it would not be too difficult to put together a little standalone application that takes gcode, looks for any G1 moves that happen above a given Z height threshold, and modifies them to G0. But if someone has, in effect, done that already, then I'd rather take that route!
22-11-2020 #2..Clive
22-11-2020 #3
That's great, Clive - many thanks. I'm sure that I saw reference in a forum somewhere as I don't usually browse Github but that's the definitive source, clearly.
I'll give it a try sometime soon but I'm struggling with some issues with my ET6 controller and MyCNC software at the moment. Basic stuff works fine but it all goes a bit wobbly once I try to do anything outside that. I'm not so interested in the toolchange stuff as separate files aren't a big problem for me with purely manual toolchanging but my current job seems to be spending for ever in slow positioning moves as it's not using G0. That's the one I'd like to fix!
22-11-2020 #4
No prob. It is on this forum as I posted it here under Fusio360 section of the forum
http://www.mycncuk.com/threads/14020-Fusion-360-news..Clive
22-11-2020 #5
Maybe I should have looked here first...
Thanks again, and apologies for the increasingly-flaky memory
04-02-2021 #6
Hello Neale,
I apologize for the late reply - our team checks this forum somewhat sporadically, so we have missed your comment. If it's not too late, we'd be happy to take a look at the issues you're having with myCNC - you can reach out to me directly at ivan [at] pv-automation [dot] com, or at our online technical support forum.Puruvesi Automation engineer working on the myCNC project.
04-02-2021 #7
Thanks, Ivan. I have been having problems with tool-height setting macros, but I need to analyse exactly where the problems are. I shall do some testing and then post in the tech support forum as suggested. I have also been looking at switching to Linux which I know is the preferred platform for MyCNC rather than Windows so I shall test on Linux (latest version from your website) before I go any further.
04-02-2021 #8
Sounds good Neale.
We do indeed encourage people to use the myCNC software with Linux rather than Windows - let me know if the issues persist there. And as always, if any questions come up with regards to using myCNC on Linux, writing macros, etc, we'd be happy to assist you.Puruvesi Automation engineer working on the myCNC project.
4 Weeks Ago #9
Hi Neale,
I have a free online tool that does exactly what you are asking for.
Open your .NC file, set the Z clearance height and press "Convert to Rapids". Click "Save" to get the new file back.
It will find all the slow G1 feeds at or above the clearance height and convert them into fast G0 rapids. It also tells you how much time has been saved.
It's all done in your browser using javascript so your file are not uploaded anywhere, and nothing to install.
Let me know if you have any questions or suggestions.
https://ultranc.com/gcode-viewer/app/
4 Weeks Ago #10
Many thanks for the suggestion but I have now built the tool mentioned above into my F360 workflow and it handles both the G0/G1 rapids issue as well as managing toolchange issues. It is not so good working on gcode for my CNC lathe but that is another issue altogether!
Good luck with your online tool.
- Brian
Lichuan "Easy Servo" closed loop stepper question
By Voicecoil in forum Stepper & Servo MotorsReplies: 15Last Post: 09-10-2019, 09:33 PM -
BUILD LOG: "Henge", 3 Axis Cnc, Fixed Gantry, Moving Table
By Greeny in forum DIY Router Build LogsReplies: 15Last Post: 20-03-2017, 08:43 PM -
"Hacking" and "Modding"
Interesting Article "Makers unite - the revolution will be home-made"
By Fivetide in forum General DiscussionReplies: 4Last Post: 28-09-2012, 12:06 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM
