    Hi, I have a part of a. Obj model that I've purchased. I can't open the main part of it (it's a skull, the lower jaw runs fine, but the upper part doesn't).
    I've tried on a friend's machine with dedicated graphics and not having any luck either, so I can't figure out if it's the file or, most likely the pcs lack of ability!
    If anyones happy to help please let me know and I'll dm a link(300mb dl).
    Thanks so much, Mark.
    I have a fairly meaty pc and use space claim which will open and save obj files
    Let me have the link and I’ll try it for you
    Cheers. Paul
  3. The Following User Says Thank You to depronman For This Useful Post:
    Thanks Paul, will pm you!
  5. #4
    Quote Originally Posted by mark84 View Post
    Mark
    I can open the file in space claim but it is massive
    I’ve tried all the setting that I understand but it will only reduce to 1.47 gb (from 4.7gb)
    I saved it as a obj and an stl file both about the same size at 1.47gb
    I then tried to open the stl file in mesh maker but got an out of memory error
    This was on my main pc with 16gb ram and an 8gb graphics card
    Not sure what else to try
    Paul
  6. The Following User Says Thank You to depronman For This Useful Post:
  7. #5
    Thanks for trying!
  8. #6
    I will be happy to try ..
    Using Rhino I can open obj models, at least an online download of Ironman, 16 MB, worked fine.
    Using an industrial PC with Nvidia graphics and 8 GB RAM on the graphics card.
    A 1 GB Rhino 3D files works fine..
    a full detailed VMC modelled in 3D.
  9. The Following User Says Thank You to hanermo2 For This Useful Post:
  10. #7
    I'll send it over!
  11. #8
    I can help you with this if your struggling.
  12. The Following User Says Thank You to Filco For This Useful Post:
  13. #9
    Ok, I have opened the file with no problems but the model has a very high and dense mesh count with errors. See image.
    My workstation is fairly high spec with a Quadro P5000 and 128gb RAM, so you will need a decent GPU and plenty of RAM.
    I have opened it with Blender and Rhino3d no problems, Blender is a free download if you want to try it.
  14. The Following User Says Thank You to Filco For This Useful Post:
  15. #10
    Quote Originally Posted by Filco View Post
    That's one amazing set up you've got! Way way beyond my budget. Thanks for checking it out, is it cheeky to ask if you could reduce the polys to make it accessible to a circa 2010 pc!? I only want to route it, the huge amount of detail isn't ever going to be visible for my application. Thanks again, Mark
  1. Fancy a different project?
    By Neale in forum General Discussion
    Last Post: 21-06-2020, 10:54 AM
  2. Newbie Machine Build Log (Fancy Machine)
    By Fancy in forum Gantry/Router Machines & Building
    Last Post: 18-09-2018, 06:15 PM
  3. DRO's are the fancy -looking ones worth it?
    By SparkyLabs in forum Machine Discussion
    Last Post: 09-01-2017, 10:14 AM
  4. Fancy a screw? Identify this leaky biatch!
    By Lee Roberts in forum General Discussion
    Last Post: 30-08-2012, 09:57 AM
  5. Fancy a challenge?
    By cassius in forum Machine Discussion
    Last Post: 03-09-2010, 02:44 PM
