Hi All,
I have settled on sticking with the X3 I already have and not to buy anything else. I plan to ditch the pulleys I made for the spindle drive and to use a couple of ratios of pre-made toothed pulleys with belts, I just need to make the plates for mounting and a tensioning system - whether that is spring loaded or moving slots is one decision I hope to make with some advice from the knowledgable people here. I will do this once I have the mill moving under cnc control. With the flexibility of the VFD/3 phase motor I don't envisage having to change the ratios too often so this could have a bearing on this decision.
Having spent lots of time reading around here I'm conscious of the regular advice not to buy electronics etc. I will be looking to add a 4th axis in the future, so need to have the capacity for this in the electronics I buy so a 4 axis motion controller
Having said the above, I have just bought some second hand but little used Nema 23 3.1nm steppers + 8mm couplers, originally purchased from cnc4you. They were too good a price to miss. I plan to use these for the X and Y axis motion. I'd like to use UCCNC as it is getting very good reviews and seems well supported with well matched controllers...
Some questions I have are
1. What controller card would suit - I have looked at the AXBB-E, the schematic shows it should do everything I need with the X3 now and in the future due to the capacity for the A axis drive
2. What are the best stepper drivers bearing in mind...
3. I perceive that Nema 34 is the correct size for the Z but could a higher torque NEMA 23 geared down do the job just as capably?
4. Is there a suitable power supply option to buy off the shelf or am I better off making my own?
5. Is anyone who has experience in converting the X3 up for helping out with specifying ball screws, mounts, bearings and maybe doing a bit of machining too? (JAZZCNC I'm wondering if you're interested as I see in Kered's BF28 build you have experience with Sieg...) I'm keen to get this machine cutting things for my hobbies...
6. Finally for now - does anyone know what happened to John Stevenson's X3 conversion pdfs that used to be on the web? I can't find them any more and didn't save them locally - they were a great resource for me.
Thanks all and stay safe,
Geoff
Warco WM18 or WM16B
By hedeon in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 25-08-2021, 12:44 PM -
CONVERSION: Warco WM18 Mill Stepper motor advice
By Gotty101 in forum Conversion Build LogsReplies: 7Last Post: 18-08-2018, 05:06 PM -
Siege sx3 or Marco wm18
By terry1956 in forum Machine DiscussionReplies: 3Last Post: 09-02-2017, 12:02 AM -
Super sieg x3 conversions
By dazza in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 19-02-2014, 10:28 AM -
Wabeco F1410LF vs Warco WM18 vs Sieg X3
By abfa9358 in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 02-08-2009, 08:23 AM
