25-04-2021 #12
I basically didn't like the amount of front overhang so wanted my saddle to move closer to the column.
I cut my base slot a bit, made some new bolt holes instead of using the large central one on the carriage.
Managed to get my saddle to move further back by 15mm. Overall I got 204mm movement from it with barely any extra overhang.
However. My throat is only 185mm but at least I don't need to hang off the front a mile. Later on I'll stick a 20mm spacer between the slide and head. Then I could use the whole 204mm.
This is on an Amat25lv similar to the Warco machine.
Warco WM18 or WM16B
By hedeon in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 25-08-2021, 12:44 PM -
CONVERSION: Warco WM18 Mill Stepper motor advice
By Gotty101 in forum Conversion Build LogsReplies: 7Last Post: 18-08-2018, 05:06 PM -
Siege sx3 or Marco wm18
By terry1956 in forum Machine DiscussionReplies: 3Last Post: 09-02-2017, 12:02 AM -
Super sieg x3 conversions
By dazza in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 19-02-2014, 10:28 AM -
Wabeco F1410LF vs Warco WM18 vs Sieg X3
By abfa9358 in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 02-08-2009, 08:23 AM
