Thread: Gear reducing kit recommendation
Those screws where 2525 with 2:1 ratio using 8Nm 3phase closed loop motors and mains drives. They also had fixed ends at both ends of the screws and where preloaded slightly to tension the screws.
I don't think Jonathan does much with DIY CNC anymore as he's working now he's left university. I bought the last 6 sets he made. These are what I used on the 10 x 5 Router.
No probably about it, I'm 100% sure because I've worked on them, only last week I converted a router which used them and it was sloppy as hell. Just about every Chinese router I've worked on uses them.
Exactly, I've built quite a few large machines now that use 3 phase closed motors with mains drives and never had any issues with reliabilty or setting up with more than enough power and speed for even large machines, they are pretty much plug n play fit and forget.
I also have 600w Chinese servos fitted to my plasma machine which are way more powerful than required and nothing but a pain regards tuning.
If I was fitting servos to a router that used Rack n pinion then I'd only fit higher quality servos like, yuskawa, Mitsibishi or panasonic which provide tuning software to help with setting them up, esp with dual axis motors.
In terms of precision then yes 0.05mm will be more than enough for 3D work in woods. If all you are cutting is mostly woods, plastics etc then I wouldn't get bogged down with chasing high precision because it's pointless in materials that can't hold it anyway.
I would pay the extra 100eur and go for 32mm, it will be worth it and lower the chances of whip if your rotating the screw.
I would avoid these, I have worked on a machine that used those anti-backlash untis and was not impressed at all. They where difficult to setup and where constantly needing adjustment. They also caused premature wear on the rack/pinion. The Rack was low quality and wore out within 1 year and as been replaced with helical rack I believe.
They are rare in DIY because they are not cheap but most good engineering suppliers will be able to supply them.
Rotating ballnuts are not so common and might require you have your own made. This is the only other place I have seen rotating ballnuts. Use google translate.
https://team-haase-shop.de/maschinenelemente.html-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
25-12-2020 #2
Very elegant setup. Just now I noticed that it is rotating nut driven as you mentioned.
I have found those before, but max nut size is 20mm, while I should look for 32mm as you suggested. So I will try make it locally. I guess 20mm is too low.
I think you are 100% right then. Thank you for saving me money.
Thank you for saving me money, again.
Could you let me know where can I get motors you used?
And thank you again for helping.
25-12-2020 #3
Look again because now they have 25 and 32 versions.
These are what I use. They are not the cheapest and for not much more money you can get servos, but like I say they are simple and reliable without any of the hassles servos introduce. I've fit dozens of sets so far and never had a single issue.
https://www.aliexpress.com/item/3279...7c1f6f37fvbQyT-use common sense, if you lack it, there is no software to help that.
Reducing 12v DC to 0.5V DC no more than 1A draw
By AdCNC in forum General ElectronicsReplies: 18Last Post: 31-12-2022, 08:14 PM -
Simple 3D Gear design software recommendation
By Leadhead in forum CAD & CAM SoftwareReplies: 22Last Post: 11-11-2017, 01:30 PM -
Reducing noise during run with box enclosure
By Skydeals in forum Machine DiscussionReplies: 4Last Post: 12-02-2015, 08:43 PM -
Reducing costs
By tonygagey in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 13-08-2014, 11:33 AM -
My first gear, a deadbeat escapement gear for my clock
By clockman in forum Woodworking Project ShowcaseReplies: 9Last Post: 30-01-2011, 11:39 PM
