Thread: Gear reducing kit recommendation
Found it and sent them email. Thanks.
These are what I use. They are not the cheapest and for not much more money you can get servos, but like I say they are simple and reliable without any of the hassles servos introduce. I've fit dozens of sets so far and never had a single issue.
Those got very high inductance. 18 mH. Is this issue? They operate on high voltage to compensate i guess and three phases. These do not need power supply, right?
On the other forum I was reading that most important is low inductance, because it enables torque at higher rpm. I am not able to find toque curve for these.
Previously I was looking at these. 2 mH, 5 Nm
https://www.ebay.com/itm/Free-Ship-4.../274560683235?
But can't find torque curves for either of them.
27-12-2020 #2
It's all relative to the Voltage, these run on 220Vac so higher inductance isn't an issue. Like I say I've fit dozens of sets and I now stock these motors/drives and fit them to all the larger machines I build. They spin fast and have plenty of torque.
For instance, the vertical 10 x 5 router I recently built uses a single 10Nm motor on the gantry (X-Axis) with a rotating ball nut that lifts the Z-axis which carriers a heavy ATC spindle and all the pneumatics, etc. That motor lifted my friend who weighs 120Kg and the spindle etc clean off the floor at 15mtr/min so I wouldn't be too worried about high inductance or lack of torque.
No, they don't need PSU they run directly from the mains supply.
I wouldn't trust that datasheet, I've never seen any Nema 34 motor with 2Mh inductance, most 3-4Nm Nema 23/4 have an higher inductance than that.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Reducing 12v DC to 0.5V DC no more than 1A draw
By AdCNC in forum General ElectronicsReplies: 18Last Post: 31-12-2022, 08:14 PM -
Simple 3D Gear design software recommendation
By Leadhead in forum CAD & CAM SoftwareReplies: 22Last Post: 11-11-2017, 01:30 PM -
Reducing noise during run with box enclosure
By Skydeals in forum Machine DiscussionReplies: 4Last Post: 12-02-2015, 08:43 PM -
Reducing costs
By tonygagey in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 13-08-2014, 11:33 AM -
My first gear, a deadbeat escapement gear for my clock
By clockman in forum Woodworking Project ShowcaseReplies: 9Last Post: 30-01-2011, 11:39 PM
