Thread: Gear reducing kit recommendation
28-11-2020 #2
I've absolutely no knowledge on the subject of rack and pinion... pretty much no knowledge of most other things to be honest, but... am I missing the plot here... if you're talking of gearing the the pinion, then surely the tooth count of the pinion is essentially the gearing component?, If you go from a (e.g.) 60 tooth pinion to a (e.g.) 20 tooth pinion you'd effect a 3:1 reduction.
Or am I being stoopid?
EDIT: Not trying to answer (or validate) the question, and so this response is clearly off-topic, but just casual curiosity. Also, would think the above could avoid introducing additional backlash in a gear chain
EDIT 2: Just reversed the example tooth count above, having woken up a bit.
Reducing 12v DC to 0.5V DC no more than 1A draw
By AdCNC in forum General ElectronicsReplies: 18Last Post: 31-12-2022, 08:14 PM -
Simple 3D Gear design software recommendation
By Leadhead in forum CAD & CAM SoftwareReplies: 22Last Post: 11-11-2017, 01:30 PM -
Reducing noise during run with box enclosure
By Skydeals in forum Machine DiscussionReplies: 4Last Post: 12-02-2015, 08:43 PM -
Reducing costs
By tonygagey in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 13-08-2014, 11:33 AM -
My first gear, a deadbeat escapement gear for my clock
By clockman in forum Woodworking Project ShowcaseReplies: 9Last Post: 30-01-2011, 11:39 PM
