28-11-2020 #1
Hi we are completely new to this and are in desperate need of some advice. We design on fusion 360 in mm and then save as a DXF file transfer over to V-carve and then transfer again to our CNC machine. On V-carve we set up our tool paths and board size again in mm, exporting them as a Tap file G-code and save to the Rich Auto pendant. We have been machining for about 4 months and have not encountered this problem yet. As far as we are aware we have not changed anything on the pendant, so maybe this is a change that has been made by mistake or something to do with the machine.
We have tried everything we can possibly find on our pendant to change the working parameters and working scale and have reset the pendant to the factory default setting. The only thing we can find to change the working parameters is "Menu" then "machine setup" then "table size" then within that menu it reads
Unit mm
X size 1300.000
Y size 2500.000
Z size 200.000
These are all correct to the size of our machine bed. For a 305mm (x axis) x 520mm (y axis) board they are working at nearly 1500mm (x axis) more and about 1000mm more (y axis).
If any one can suggest any solutions we would be very great full, Thanks.
RFQ: small parts for 1/14 scale rc trucks
By Rebekah_harper in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-01-2016, 10:20 PM -
First build - Mid-scale gantry router design
By Ellis in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 20-05-2015, 11:43 PM -
those £55 usb bob's and those £5 tb6560 drivers pic for scale of them = tiny!!
By nobby in forum General ElectronicsReplies: 11Last Post: 01-06-2014, 04:40 PM -
WANTED: Wanted Linear Scale/Encoder
By gavztheouch in forum Items WantedReplies: 9Last Post: 24-01-2013, 05:32 PM
