29-12-2020 #1
Hi There
I am newbie to the site and should just point I am very much amateur in CNC although have been playing around with CNC for quite few years
I am slowly building a large CNC, I currently have a small A4 machine but want something I can use to make furniture out of.
The dimension will be roughly 1700x1100, it will be loosely based on the open builds rails but I want to use sfu1605 instead on acme 8mm screws.
So far I have bought the rails and a SFU1605(imported from china) for the Y axis and I trying to source the ballscrews for the X axis. One thing I regret not looking into before was whether to get a ballscrew with anti-backlash my current one doesn't have this built in.
My question is does anyone have any experience with the imported SFU1605 ballscrews and will the lack on anti-backlash be a massive problem this will very much be a hobby style machine rather than anything professional.
I've also seen you can buy anti-backlash nuts that i assume you can install on pre-existing rails has anyone tried this and again and does it give good results ?
Also if any one has recommendations for the X axis ballscrews about 1200mm in length that would be great i am afraid budget it tight so probably looking to import them again
Any advice would be greatly appreciated
James
Hobbymat BFE65 Leadscrew info, fitting anti backlash nuts
By manofgresley in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 09-05-2014, 04:35 PM -
Maximum length guideline for a standard 16mm ballscrew?
By WandrinAndy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 01-11-2012, 12:27 AM -
Source of multi-start ACME or Metric Trapezoidal Leadscrew and Anti Backlash Nuts
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 16-03-2010, 10:11 PM -
Commercial Sieg X1 anti backlash nuts ?
By cweeks in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 28-05-2009, 06:41 PM -
Anti-backlash bearings for acme screws
By RichardPiper in forum Lead Screws, Nuts & SupportsReplies: 19Last Post: 16-06-2008, 08:34 PM
