    I bought a 4.2 Frame laser (30W at the barrel ??) and it had a fixed focus laser module on a fixed height mount on the gantry.
    So I made a mini Z axis with my 3D printer, using M6 brass theaded rod as a leadscrew and a stainless steel square nut. The guide rails were 6mm brass rod and the nema17 and coupler were all in a box under the bench. So far I have only bought an E-clip set (yet to arrive) to use two clips to stop the guide rods from moving, everything else I had already.
ID:	29204Click image for larger version.
    Quite pleased with the result. Bear in mind it is for a laser, so no cutting forces and also it doesn't constantly move up and down, it just sets laser focus height for the job.
    Now I need to get the thing commissioned and set up.
    Cheers,
    Rob
    That's all very neat.
    And e-clips - always handy to have in.
    I am curious (££) what a "4.2 frame laser" is, especially with a laser module rather than tube (it's almost worth abandoning a K40 for a 30W solid-state laser)
    EDIT: Oooer, just looked on eBay - very attractive pricing. What's your experience with these lasers?, any good?, DoC for ply/acrylic? Hmmm, the first hits on eBay typically quote input power, optical power is closer to the 7-8W in the modules that I've seen. Still useful for many things and a lot less bulk than a K40 with cooling systems.
    Hi Doddy.
    It looks like this
Name:	Frame laser.jpg
    I bought it as a lockdown toy and it cost £199 from CZ republic. I don't believe 30W from the gun as the power supply is only 12v 5A and it has to power the motors as well - we shall see. The machine came as a kit with a fixed focus laser module, so to get the focus at 20mm you would have to prop the workpiece, which I did not like.
    The software with the machine was CRAP so I ditched the controller and told the supplier it didn't work and got a £20 refund on it.
    I wanted to use Gcode generated by the JTech laser Inkscape add-on. I am still waiting for a DC power plug to arrive as the Cronosmaker board I bought has a 2.5mm pin in the socket and the power supply has a 2.1. (and the eBay twat sent me 2.1 panel sockets).
    In the meantime, I am venturing into the world of GRBL controllers.
  4. The Following User Says Thank You to cropwell For This Useful Post:
  1. DIY Laser levelling using webcam and laser level
    By devmonkey in forum Gantry/Router Machines & Building
    Last Post: 12-04-2023, 06:25 PM
  2. SPT Laser: How to choose a suitable co2 laser tube
    By Rokey in forum Manufacturer News
    Last Post: 20-11-2019, 10:19 AM
  3. Redsail M500 mini laser engraver needs a new laser tube ???
    By shindax in forum Laser Machines & Building
    Last Post: 12-10-2019, 02:21 PM
  4. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  5. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
