Thank you for the excellent reply. Well, excellent except that I have more work to do...
I thought I would just clarify something about the computer PSU. I am using it because I need 5V for the controller as well as an Arduino, I want 12v for the fans and I figured it had more than enough juice to give me 24v through a boost converter. Just in case you thought I was actually using it in the PC which will feed the controller - I am not; I will be using a separate laptop. I do have a 24v PSU but I figured the controller only wanted 500ma and seemed overkill having another supply. All the grounds of 5v, 12v and 24v would therefore be the same. Does it still sound like a bad idea? Should I have separate 5v, 12v and 24v supplies?
Thank you for your input
Proximity sensor false triggers AFTER grounding it's shielding.
By Nealieboyee in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 03-09-2020, 07:02 PM -
servo cables?
By Ross77 in forum Stepper & Servo MotorsReplies: 12Last Post: 26-07-2017, 05:01 PM -
Replacement cables
By Paul B in forum Chinese MachinesReplies: 6Last Post: 25-04-2017, 11:24 AM -
Which cables to shield?
By andy586 in forum General ElectronicsReplies: 0Last Post: 02-07-2014, 04:33 PM -
USB repeater cables
By Web Goblin in forum General DiscussionReplies: 0Last Post: 21-05-2011, 12:36 PM
