Page 2 of 2 FirstFirst 12
    So bear with me on this or maybe the I-phone users will point me to an easy way. My new Android also saves pics in HEIC so that windows cant manage them.
    It does however put them into google photos so i can download them . I then use an online converter for jpeg, so lets see if it works.
    2 pics .
ID:	29729 Click image for larger version.
    First shows my adaptor for tool block fitted to slide using existing tapped holes, and my initial attempts at a "rear" parting off toolpost .
    Second shows improved PO toolpost, with T37 tool block above . I am using a narrow tip tool for the sort of profiling which is generated by Mach Wizards .
    Have to say that Mach 3 wizards have some very inefficient routines , but like the old bike , good enough to learn on.
    Parting off on TCL with 20mm bar struggles a bit so will be looking to see if my DC controller can boost a bit
    Seemed to work , but if I click the pics they get turned 90 degrees , so you may have to lie down for a good look
    Are you using the original motor and lenze controller Will?
    My TCL125 has a factory fitted Dickson QCTP of the same size as is sold for the Myford Super7 and ML7.
    Mine are aftermarket copies but the same size and reasonable enough for me . The genuine article would probably have cost me more than the machine did.
  1. Replies: 0
    Last Post: 15-08-2017, 04:13 PM
  2. Boxford TCL 160 tool alignment
    By Saracen in forum Boxford Lathes
    Last Post: 05-11-2014, 10:28 PM
  3. WANTED: Boxford design tool Software V10
    By weeden007 in forum Items Wanted
    Last Post: 15-02-2013, 04:24 PM
  4. 7 x 12 tool post modification
    By fragger6662000 in forum Milling Machines, Builds & Conversions
    Last Post: 25-09-2011, 10:02 PM
  5. WANTED: Boxford 125TCL Tool holder?
    By Minnican in forum Items Wanted
    Last Post: 16-02-2011, 09:22 PM
