  1. #4
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by cpf View Post
    I have just checked our G code and it is reading G17. I have changed it to G21 it made no difference so i thought i would try G20 as well just to see what would happen it just ploughed straight down into the board so i quickly cancelled it as i didn't want the machine to get damaged.
    I am starting to think that maybe there is a dodgey connection some where as i am unsure as to why this is happening. We have had the pendant apart to check everything is in tact in there and all is fine.
    Thank you for your advice!
    G17 is the XY plane G20 is for imperial and G21 is for metric.
    Are you sure that the drawing scale is in mm and not inches ?
    In the MDI type G1 X0 F200 then G1 X10 F200 Then check to see if X moved 10mm
  1. CNC Programmers Needed in West Midlands
    By EncoreTechnical in forum Opportunities Available & Sought
    Last Post: 09-03-2012, 10:28 AM
  2. NEW MEMBER: Hi from West Midlands
    By wiatroda in forum New Member Introductions
    Last Post: 09-02-2011, 10:42 AM
  3. NEW MEMBER: Hi all from west midlands
    By phillip in forum New Member Introductions
    Last Post: 28-01-2011, 10:18 AM
  4. NEW MEMBER: Hello from West Midlands
    By range3rrr in forum New Member Introductions
    Last Post: 25-09-2010, 01:58 PM
  5. NEW MEMBER: Greetings from West Midlands
    By Steve Grafix in forum New Member Introductions
    Last Post: 23-08-2007, 01:33 PM
