Never used extrusion, but thought it was assembled with angle brackets and T bolts ?. if you want to drill a hole through the section you will require a steel sleeve(preferably hardened) of the required size, ie tapping or clearance. rough out a piece of oak or similar hard wood say 100mm long and square section larger than the slots in the profile, drill a hole slightly smaller than the OD of your sleeve in the centre at whatever distance from the end suits your needs and press in the bush, thickness the wood to get the bush dead central and a good fit in your extrusion slot and your hole will be central to the slot.
Regards
Mike
NEW MEMBER: New joiner from the centre of England
By BDH in forum New Member IntroductionsReplies: 4Last Post: 21-02-2020, 04:58 PM -
The dude butchered my aluminum extrusion :( !!!
By Fancy in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 06-01-2019, 06:35 PM -
8020 T Slot Aluminum Extrusion
By Fivetide in forum Marketplace DiscussionReplies: 9Last Post: 26-11-2016, 12:37 AM -
NEW MEMBER: where to buy aluminum extrusion
By troyboy1 in forum New Member IntroductionsReplies: 3Last Post: 21-07-2014, 01:52 PM -
NEW MEMBER: *stands up* I'm mc...
By m_c in forum New Member IntroductionsReplies: 2Last Post: 08-09-2008, 02:21 AM
