Hi CPF,
Well first off I wouldn't recommend Mach3 as it's not unsupported and getting a little long in the tooth. Its replacement is Mach4 but this is very buggy and not the easiest to get up and running.
My strong recommendation would be to go with UCCNC Software and use UC300ETH controller hardware. I could make a long post explaining why and all that's involved but instead, I'm going to PM you my number and ask you to give me a ring. I can explain much better on the phone all that is involved in retrofitting, I can even provide you with the Hardware and Software license which you'll require.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Looking for advice on converting driver on Boxford CNC Router to Mach3/4
By yankyg in forum Boxford RoutersReplies: 8Last Post: 20-02-2019, 11:40 AM -
Changing to Hiwin design from round supported parts advice grateful.
By grain_r in forum Gantry/Router Machines & BuildingReplies: 23Last Post: 16-09-2016, 08:47 PM -
Changing velocity setting in Mach3 (stalling)
By d4cnc in forum Machine DiscussionReplies: 3Last Post: 12-04-2016, 12:04 AM -
USB/Ethernet controller for Mach3/4 advice
By paulus.v in forum Control Hardware & SystemsReplies: 17Last Post: 17-02-2015, 09:37 PM -
Orac lathe to Mach3 conversion advice/direction please
By Hunter in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 18-08-2014, 09:36 PM
