Thread: Losing steps
    On a 700mm x 500mm piece of sapele doing a roughing cut with 8 passes I’m losing 2mm on each pass on the y axis, it only shows itself at the end of the cut but it starts at the right point for the next cut
    Quote Originally Posted by Edendale View Post
    That statement requires a bit of elaboration.
    Do you mean (and I'm possibly mis-interpreting your words here), that for each successive pass, the X/Y recovers to the same position (exactly the same position, no 2mm/pass offset)?
    If so, can you post your g-code?
    Hi Doddy, I might be wrong about it starting again at the same place it’s hard to tell,
  1. Losing steps/position, again
    By ngwagwa in forum Artsoft Mach (3 & 4)
    Last Post: 30-04-2020, 12:23 PM
  2. Losing steps
    By Edendale in forum General Discussion
    Last Post: 06-03-2020, 10:10 PM
  3. Router losing steps. Solution needed. Will this help?
    By cncbobuk in forum Chinese Machines
    Last Post: 27-12-2017, 03:40 AM
  4. Losing steps on Z axis
    By Arzo10 in forum Machine Discussion
    Last Post: 31-03-2017, 10:49 AM
  5. New Mill losing steps
    By lukecnc2012 in forum Gantry/Router Machines & Building
    Last Post: 08-11-2014, 02:56 PM
