    Sounds like you might benefit more from something like this: https://www.cutwel.co.uk/lathe-tools...holders-teknik
    It will let you drill, bore, and turn all with the same tool and only take up one space on your tool post! It won't hurt the wallet too much either. The only issue you may have is that you're limited to the size you can drill, so anything smaller may be an issue. but it would work fine for your 12mm hole you need to do now, depending on the depth you need to bore of course.
    You could also go down the route of ER holders like this: https://www.cutwel.co.uk/12mm-straig...o-c12-er16-80m
    That way you could use any drill size you needed between 0.5 - 10mm depending on what set of collets you bought to go with the holder. This would be more expensive but a bit more versatile.
    Quote Originally Posted by JimJam View Post
    Great, thanks. I will take a look!
    Another thank you JimJam.
    I actually purchased both of these tools in the end. One for smaller diameter drilling (coupled with HSS Co stub drills) and the TekNik MT for 10mm drilling and boring stock.
  1. WANTED: Automatic Tool Changer for Boxford TCL125
    By TomHennessy in forum Items Wanted
    Last Post: 31-10-2020, 10:25 AM
  2. WANTED: wanted automatic chuck
    By Hellfire in forum Items Wanted
    Last Post: 10-11-2016, 11:53 PM
  3. FOR SALE: Re my Starmill with Automatic Tool Changer running on mach3
    By suesi34e in forum Items For Sale
    Last Post: 01-10-2014, 09:57 PM
  4. WANTED: Denford Triac with automatic tool changer
    By hugh_munculus in forum Items Wanted
    Last Post: 12-09-2012, 12:10 PM
  5. Automatic tool changer
    By amen23 in forum Tool & Tooling Technology
    Last Post: 06-01-2009, 05:56 AM
