I get what you mean ...and that is a possibility. I was looking at the bowl problem from the the direction of mounting the blank and machining in one go, if I mounted the blank then proceeded to mill the outside first then rechucked it as I would under normal circumstances, then milled the inside to finish, problem solved. I still may be better off mounting the router on a rotary table on the cross slide ... I am assuming that I would continue to keep the blank turning in the standard direction to get the cutter into a 'reversed' or concave bowl lip. I had fallen into my normal trap of overcomplicating things...
Tim G-C
“I disapprove of what you say, but I will defend to the death your right to say it.”
(attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
14-02-2010 #2
Yes think you might need the rotary table if using a normal router,something like this may work without because of the small body http://www.mycncuk.com/forums/showth...ight=brushless ,but it does mean your in for a lot of work with the total conversion,the good thing about using a router/spindle is the speed will do all the work,so you could drive your lathe chuck very slow,maybe with a stepper motor,the motor would run continually for turning work and then index round for your fluting,barley twists or any holes you need round the circumference.
Steve.
14-02-2010 #3
Sorry to piss on your chips but from the looks of that machine, nice as it is, it's not a real candidate for a CNC conversion.
You would probably be a lot better off selling it or using it as a second op machine and starting with a clean sheet of paper.
What you want to do has been done before in various stages, simple linear rails for the bed and cross slide and a double drive system for the head as Steve says, motor to spin at speed for turning and stepped geared drive for barley twists etc.
.John S -
14-02-2010 #4
Well hope you get it sorted mate,so you can get back to making a living.
Steve.
Hand held laser cutter
By Robin Hewitt in forum Tool & Tooling TechnologyReplies: 9Last Post: 24-10-2013, 06:05 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
MIT Students Hand Held CNC Router
By mekanik in forum Marketplace DiscussionReplies: 1Last Post: 26-09-2012, 12:49 PM -
FOR SALE: Coronet Minorette Wood Working Lathe
By AdCNC in forum Items For SaleReplies: 0Last Post: 21-10-2010, 11:54 AM -
NEW MEMBER: Wood Lathe - fitments
By Musochasle in forum New Member IntroductionsReplies: 16Last Post: 10-08-2010, 08:28 AM
