The one you have will work. But I am not familiar with this it.
The one that I would use (if you could send it back) would be the tried and tested :-
https://www.ebay.co.uk/itm/Speed-Con...sAAOSw97RfAuIN
some of the important settings is the motor number of motor poles I think it is 2 if you have the Chinese 2.2kw spindle
and the input voltage & current. Also the max frequency 400Hz so the the spindle will run at 24K..Clive
13-12-2020 #2
I've just found this sheet that is to the VFD I have, I've set as listed but not sure about the middle & low frequency & voltage settings, they don't look right to me, I'll attach a copy
thanks
Allan
vfd query about the program settings for XSY-AT1 and air cooled spindle
By marbles in forum General ElectronicsReplies: 17Last Post: 11-09-2019, 11:19 PM -
Water cooled vs Air cooled spindle for wood
By Bucks in forum Machine DiscussionReplies: 5Last Post: 06-02-2017, 01:58 PM -
Water cooled / air cooled 2.2kw spindle
By suesi34e in forum Generic Chinese SpindlesReplies: 15Last Post: 25-02-2015, 04:57 PM -
Do you need to water cool erhm a water cooled spindle?!!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 18Last Post: 02-10-2013, 09:59 PM -
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM
