cheap but without making it useless! basically you can buy pathetic hand tools for £2k that you just put your arm on and slide around from part pickup to placement but I see that as problematic as you need fine motor control and in the demo of how fast you can go parts are not dropped right and of course they neglect the time taken to hunt out the parts locations so they are just matching footprints for effect. If I can buy a good base with motors and drivers for under £300 then that's a really good start but a bit bigger than 300x160mm would be good as if I can put multiple boards on (they can easily be 200x100mm each) this further greatly speeds up the processing even as a man in the loop.
19-12-2020 #2
https://www.amazon.co.uk/VEVOR-Engra...&sr=8-277&th=1
Finally one that admits to 80-100µm accuracy not bad, that's within 20% correct for a 0.5mm pitched part but for just over twice the money the other one is twice as accurate with twice the working space.
FOR SALE: Gravograph L solution 300
By petesurrey in forum Items For SaleReplies: 0Last Post: 30-12-2018, 02:41 PM -
Is having a wobbly bottom normal? Drill Vice...
By Dangle_kt in forum Workshop & EquipmentReplies: 9Last Post: 13-01-2017, 04:39 PM -
1st time setting up.. whats normal..
By Marlin in forum Motor Drivers & ControllersReplies: 26Last Post: 01-09-2014, 04:53 PM -
Hold down solution
By jonbabbz in forum General DiscussionReplies: 4Last Post: 11-10-2012, 08:21 PM -
Looks like the normal first page has gone awry.... or is it my PC?
By WandrinAndy in forum General DiscussionReplies: 22Last Post: 03-10-2012, 08:05 PM
