19-12-2020 #3
T8.= Trapezoidal screw - that's likely to bugger your positional accuracy requirement unless you introduce some anti-backlash mechanism. Stepper "42" - can't see that in the link, but could be related to the frame size that translates to a NEMA17 motor - it's just an indication of size and expected power range. Most common steppers are 200 steps/1.8 degree/step resolution. On a T8 that's 25 steps per mm or 40 micron - but you could pretend that micro-stepping offers higher resolution. Of course that assumes everything about the screw thread linearity / accuracy, as well as the frame geometry. Do you really need 100 micron accuracy? I don't think so (I'm pretty sure that working with 0402 components I'm not that accurate by hand).
How are you planning to feed your P&P - what's the component delivery mechanism? How are you going to achieve component alignment (and necessary re-alignment...particularly with vibration moving through the frame). Have you not thought of solder stencilling or solder-paste deposition as a "glue" for the components before placement?
I spent a few months in a clean room pick&place PCB assembly room when I was "a lad" - okay, quite a few years ago, but working incredibly compact boards (and high layer-count PCs) and the early generations of SMD devices. P&P with a less than heavy investment can go spectacularly wrong quickly.
I'd be interested to hear how you get on; unfortunately none of my projects get anywhere near complicated enough to make me desire such a machine myself.
Edit: reference to 0402 - I tried to prove I could... I much prefer 0603 for sanity, or 0805 to rent out as student digs :).
Surface tension of molten solder will draw components into alignment over distances substantially greater than your 100 micro accuracy.Last edited by Doddy; 19-12-2020 at 09:06 PM.
FOR SALE: Gravograph L solution 300
By petesurrey in forum Items For SaleReplies: 0Last Post: 30-12-2018, 02:41 PM -
Is having a wobbly bottom normal? Drill Vice...
By Dangle_kt in forum Workshop & EquipmentReplies: 9Last Post: 13-01-2017, 04:39 PM -
1st time setting up.. whats normal..
By Marlin in forum Motor Drivers & ControllersReplies: 26Last Post: 01-09-2014, 04:53 PM -
Hold down solution
By jonbabbz in forum General DiscussionReplies: 4Last Post: 11-10-2012, 08:21 PM -
Looks like the normal first page has gone awry.... or is it my PC?
By WandrinAndy in forum General DiscussionReplies: 22Last Post: 03-10-2012, 08:05 PM
