Thread: Machining rubber
21-01-2021 #11
It was an 1/8" cutter, it was only a small job and I figured a smaller cutter would be less likely to deform the material as it cut, the waste comes off like dense fluff bit the cut surfaces are nice and smooth.
I have some more things I want to do in Polyurethane but I need to build a speed increaser on a BT30 for my new CNC mill first.You think that's too expensive? You're not a Model Engineer are you? :D
Rubber/plastic flexible strip for swarf exclusion
By Voicecoil in forum Swarf & Chip ManagementReplies: 7Last Post: 12-09-2019, 12:04 AM -
RFQ: Need something machining?
By HiltonSteve in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-09-2018, 04:47 PM -
FOR SALE: Open End 3M HTD Rubber belt 15mm wide
By wiatroda in forum Items For SaleReplies: 0Last Post: 22-06-2011, 03:49 PM
