Threaded View
25-12-2020 #1
first off sorry if this is the wrong place to post it i'm new to posting here
i have one of these cheap usb controllers for mach 3 i'm using in a 190vmc conversion and all of the axis' work perfectly however i can't seem to get the spindle to work for me at all, i've looked all over trying to find how to use the 10v analog output for the speed, whatever settings i change i always get a 0v reading from the terminal, somewhere showed them using one of the output pins being used as a pwm signal, couldn't get that to work but that would be a 24v pwm signal so would need a voltage divider and RC circuit to smooth anyway.
and yes i do have the power hooked up to 24v
i've gone through a paraport bob and now this trying to get things to work right and am starting to think i should have just spent the money on a smoothstepper, would that make life a bit easier?
Mach3 Problems problems problems.
By ECCO in forum Artsoft Mach (3 & 4)Replies: 18Last Post: 09-07-2016, 10:07 AM -
Solution to M3,4,5 spindle relay problems
By Cnc many in forum General DiscussionReplies: 6Last Post: 19-12-2015, 03:18 PM -
Problems with spindle / motor
By scnc in forum Spindles & Drive MotorsReplies: 1Last Post: 15-01-2013, 01:39 AM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM -
Spindle motor problems
By geoffby in forum Motor Drivers & ControllersReplies: 11Last Post: 07-11-2010, 08:25 PM
