30-12-2020 #8
Tripping the RCD - highly probable it's something in the spindle motor. If you can still find them - replace the spindle with a 240V 60W lamp and check that doesn't blow the RCD. If you was closer I could loan you a 180VDC spindle motor instead, but Nottingham is a bit far for that.
Daft question - when did you last "properly" run the spindle?
Mach3 Problems problems problems.
By ECCO in forum Artsoft Mach (3 & 4)Replies: 18Last Post: 09-07-2016, 10:07 AM -
Solution to M3,4,5 spindle relay problems
By Cnc many in forum General DiscussionReplies: 6Last Post: 19-12-2015, 03:18 PM -
Problems with spindle / motor
By scnc in forum Spindles & Drive MotorsReplies: 1Last Post: 15-01-2013, 01:39 AM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM -
Spindle motor problems
By geoffby in forum Motor Drivers & ControllersReplies: 11Last Post: 07-11-2010, 08:25 PM
