27-12-2020 #3
Spindle speed should not affect the pitch, as when threading, the Z axis should be geared to match the spindle, so even if the actual spindle speed isn't as requested, the Z should adjust to create the required pitch/thread.
Are you 100% sure it's a 1024 PPR encoder you have?
If it was actually 1000PPR, it would throw your pitch off by about 1%, and going by the 1.475/1.5 it's off by 1.66%.
At that big a pitch with a normal nut, being 0.6% off on pitch would probably still work without any noticeable problems.
Have you checked your Z axis calibration over a larger distance?
Checking over only 1mm isn't likely to show any minor discrepancies. I'd check it over whatever the biggest distance you can using a set of digital verniers/calipersAvoiding the rubbish customer service from AluminiumWarehouse since July '13.
Ballscrew Size and Pitch
By GTJim in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 28-02-2022, 05:40 AM -
Mach3 Lathe Threading Struggles
By mondrota in forum Artsoft Mach (3 & 4)Replies: 34Last Post: 14-11-2018, 10:47 PM -
RFQ: Basic Error! - anyone have a lathe, some 10mm steel stock and a few mins please?
By TonyD in forum Projects, Jobs & RequestsReplies: 5Last Post: 14-10-2013, 06:20 PM -
Fine pitch Bolts
By Normsthename in forum General DiscussionReplies: 1Last Post: 13-08-2010, 11:13 PM -
What pitch ballscrew would you recommend?
By AdCNC in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 23-02-2010, 02:08 AM
