Thread: Stepper motor power supply
26-12-2020 #1
My Easyturn lathe has size 34 stepper drives. Servo size 34 had a different flange diameter so it looks as if hybrid stepper drives are the easy option. Unlike the servos which were mains ac voltage, the steppers are 24v dc or 80v ac. Does it make a difference which input type is used?
Steppers: motor 86BYGH4118EC-1000+ driver 2HSS86
26-12-2020 #2
Are you sure they have the option of 24vdc and 80vac input? Those numbers don't match up.
The Following User Says Thank You to pippin88 For This Useful Post:
26-12-2020 #3
Colin you have it wrong it's 24v-80Vac or 30V-110Vdc
It makes no difference which you use just make sure you leave about a 10% safety margin on the Max voltage. With large motors the more volts the better the motors will work but make sure you leave at least 10% safety.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
26-12-2020 #4
thanks for the reply, i have mislaid the original pdf with the email from szgh but i looked at the generic which said 24-70v ac or 30-100vdc. I was tempted to try their
servo driver/motors if the frame size was the same, but it is different so hybrid stepper driver/motor it will be.
The old motor could have been reused but with the new units being so cheap and connection easier to understand with it being the same manufacturer then changing everything appears the best way to go. So you are suggesting an input of 63vac or 90v dc?
26-12-2020 #5-use common sense, if you lack it, there is no software to help that.
Closed loop stepper motor kit power supply
By the great waldo in forum Motor Drivers & ControllersReplies: 19Last Post: 21-09-2019, 10:08 AM -
FOR SALE: Stepper Motor Power Supply From Zapp Automation
By MrBurns in forum Items For SaleReplies: 1Last Post: 02-10-2017, 04:54 PM -
FOR SALE: servo motor + driver + power supply, plate
By remrendes in forum Items For SaleReplies: 1Last Post: 03-08-2015, 08:06 PM -
Stepper Motor Power Question
By boldford in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 17-07-2012, 09:40 AM -
Calculating Stepper Motor Power? Strength?
By antsals in forum General DiscussionReplies: 2Last Post: 11-07-2011, 12:18 PM
