Thread: lubrication
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    They're based on a Myford ML10, so have a search for an ML10 manual.
    Lubricate the ways with some slideway lube.
    Depending on age, spindle will either be babbit bearings, which will have oilers, or taper roller bearings, which will have grease nipples.
    I have no idea what oil the oilers need, but I'm sure searching will turn up lots of discussion from Myford owners about how using the 'wrong' oil will result in instant self destruction (I'd guess any reasonable engine oil will actually work well enough).
    Grease wise, a single squirt of lithium grease, probably every 20-50 hours of operation will be more than enough. Bearings don't actually need that much grease, and too much grease is as bad as too little grease. After greasing, run the spindle at a relatively slow speed for 15 minutes to give the excess grease a chance to work it's way out.
    Ballscrew wise, when I had a Connect, I used to occasionally take of the Z-axis ballscrew cover, and put some suitable ballscrew grease on to the screw.
    X-axis, I'd do the same, but access depends on what age of lathe you have and where the stepper is mounted.
  1. Hiwin Lubrication
    By Noplace in forum Rails, Guideways & Bearings
    Last Post: 27-04-2015, 06:48 PM
  2. WANTED: Mist lubrication system
    By badgerman in forum Items Wanted
    Last Post: 21-08-2014, 12:28 AM
  3. Milling machine -maintenance? (oil, lubrication, specific questions)
    By diy-john in forum Milling Machines, Builds & Conversions
    Last Post: 24-02-2013, 09:03 PM
  4. Ballnut Lubrication / Grease
    By Mad Professor in forum Lead Screws, Nuts & Supports
    Last Post: 18-07-2012, 08:08 PM
  5. Lubrication (OOooeerr missus)
    By Smiler in forum Linear & Rotary Motion
    Last Post: 14-10-2008, 07:56 PM
