04-01-2021 #18
The other part of the motor equation is voltage. Voltage is what gives you speed.
As a motor spins faster, the back emf (electro motive force - essentially voltage that fights back against the applied voltage) increases, so in order to maintain current (which is what give you the torque), you need to apply an ever higher voltage.
The driver handles all this, so all you need to do is set the current.
As for why the motor seems smoother at lower current, I wonder if there is a fault somewhere. Without having a motor or drive to substitute, there isn't really that much testing you could do. Measuring the resistance through the coils of the motor would test for any obvious electrical faults with the motor, but they probably wouldn't be that conclusive.
My comment about precision was although Macro photography needs accuracy, it's more a case of needing repeatability, rather than pure precision. You don't really need the position to be highly accurate, you just need it to be repeatable.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
How to align ball screw to linear rail?
By Sterob in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 23-04-2020, 10:59 PM -
Ball screw advice
By Darren in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 10-04-2016, 10:52 PM -
eBay: THK KR33 Linear Actuator (Great for Z-Axis)
By biketrialsdave in forum Items On eBay UKReplies: 0Last Post: 21-01-2016, 03:17 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM
