08-01-2021 #29
There's only one word for that noise.!!. .Grrrrrrrrriiiitttttyyyyyy bad. It should be more Swissssssshhhhhhh than growwwwllllllll.
It's not unusual to feel resistance in the movement because that's the preload in the linear bearings and ball-nut, however, the sound should be more of a Swish than a growl.
So absolutely got something going in there and I'd tip it's the ball nut doing most of the growling.
I would remove the bolts that attach the carriage to the ball-nut and move the linear guides on their own. This will identify the bad guy.
I can't quite see on the video but do the rails have bolts holding them down in every hole.? If not then you could also have an alignment issue which is compounding the issue. Linear guides are great when set up correctly but unfortunately because they are precision components they don't accept sloppy fastening or poor alignment very well and will binding and can growl if the alignment or parallelism is out.
Time to move onto the next phase and take those bolts out of the ball-nut. It should soon become clear where the problem lies.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
How to align ball screw to linear rail?
By Sterob in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 23-04-2020, 10:59 PM -
Ball screw advice
By Darren in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 10-04-2016, 10:52 PM -
eBay: THK KR33 Linear Actuator (Great for Z-Axis)
By biketrialsdave in forum Items On eBay UKReplies: 0Last Post: 21-01-2016, 03:17 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM
