Step by step - disconnect the motor wiring (insulating them carefully) and see if the RCD still trips. If not, it suggests the motor insulation may be to blame. Was it being sored in a damp place?
Presumably it has a starter cap - you could disconnect that temporarily to see if it has broken down between the internals and the case.
It may have been working fine before you picked it up if the previous owner didn't have am RCD on his outlet.
Make sure the machine has a good solid protect earth connection back to the plug. If there is something dodgy going on, you should ensure that protection is dependable.
FOR SALE: Myford 280 Gear Head Lathe £2400.00
By Gary in forum Items For SaleReplies: 1Last Post: 01-07-2019, 01:11 PM -
FOR SALE: Myford ML10 CNC lathe for sale.
By John S in forum Items For SaleReplies: 3Last Post: 13-09-2013, 06:42 PM -
FOR SALE: Just seen Myford Lathe for sale in local paper ...
By Spedley in forum Items For SaleReplies: 5Last Post: 01-08-2013, 11:32 PM -
NEW MEMBER: Hi from Denbigh North Wales - Myford ML7 lathe conversion beginner
By veedub1955 in forum New Member IntroductionsReplies: 6Last Post: 27-04-2012, 11:58 AM
