Page 3 of 3 FirstFirst 123
  1. #21
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    Quote Originally Posted by Fivetide View Post
    I'll give this a go tonight when I get 20 mins spare then report back
    Yeah, that's a good test set up.
  2. #22
    FiveTide - I've offered you my phone number on PM. Or we can continue this thread here. One way is faster than the other.
    Ignore the frequency - that's a characteristic of that board that converts PWM to analogue. If you've cancelled that order, that issue is off the table.
    I really need to understand from you how much you understand what PWM is (a variable mark-space signalling standard) and TTL levels (simply a digital 0/1 representation though there are particular voltage level connotations that we can probably safely ignore given the rail-to-rail drive of the Arduino outputs). The question that needs to be resolved is: If you tie the TTL input to 5V, does the laser emit 100% power, and if tied to 0V does the laser emit 0% power (off). If that's happening, then the laser is fundamentally working.
    Next, we need to establish - if your GRBL is trying to lase at 100% power, is the PWM output from the Arduino substantially "on" (maybe > 95% mark/space). And similarly at each power level (e.g. 50% = 50% mark/space). That confirms the behaviour of the GRBL controller.
    Then you plug them together and check that still works. Back of my mind I'm cautious about any loading from the laser onto the Arduino output. TTL implies a current source level that the Arduino can comfortably handle. But the proof of that is scoping the D11 output signal. I'm also hesitant for any voltage droop on the PSU under the full load drive from the laser. Again, that's a scope job.
    Thanks for the offer, I'll try and adjust the PWM output via the Arduino library's as in the video above. If unsuccessful I'll call you probably tomorrow evening if that's convenient ?
    Ralph Waldo Emerson
  3. #23
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    One thing I've not seen mentioned, is how are the laser and arduino powered, and are they suitably connected?
    If both are powered from the same 12V supply, they should already share a common ground, but if you're powering them independently (i.e. 12V to the laser, but relying on USB power for the Arduino), then you'll need to connect the Arduino ground to the laser/12V ground. Without that connection, the TTL/PWM control circuit won't be complete, and nothing will likely happen.
  4. The Following 2 Users Say Thank You to m_c For This Useful Post:
  5. #24
    FUCK ME m_c your a genius !! I owe you one. Tapped the power off the laser 12v power + earth and ... now works. :)
    Ralph Waldo Emerson
  6. #25
    Doddy's Avatar
    A useful reminder to me to not ignore/assume the basics
  7. The Following User Says Thank You to Doddy For This Useful Post:
  8. #26
    Looking at different things, sometimes you realize that for everything you need a lot of money.
  9. #27
    I'm curious....did you get chance to test the laser power? Does it manage to cut through 8mm ply in one pass?
  1. NEW MEMBER: New member help me spend my money
    By Jiroma in forum New Member Introductions
    Last Post: 17-08-2018, 10:40 PM
  2. RFQ: Can someone make this for me? For money?
    By richardmayo in forum Projects, Jobs & Requests
    Last Post: 16-11-2013, 02:00 AM
  3. Need some money making project ideas
    By Fivetide in forum Marketplace Discussion
    Last Post: 23-11-2012, 09:50 AM
  4. Which part of *your* build leaked the most money?
    By CNCBlug in forum General Discussion
    Last Post: 08-03-2010, 07:59 PM
  5. Easy money
    Last Post: 06-07-2009, 12:39 PM
