    Muzzer, all good points, and I’ve also got two encoder on my Mesa 7i76e /lathe, and very useful it is as well, I do use them all the time (as far as I use the lather, that is)
    There are more controllers with one or two axis encoder than there are with 3 or more (these latter ones being some thing of a rarity). As far as the wireless pendants go, if these plug into your PC (rather than directly into s control card) with the machine running UCCNC or Mach, then you still have machine-in-loop and the machine is taking instantaneous demands from the handheld mpg and translating these to fragments of motion commands to the underlying controller. In which case you can manage multiple axis through the driver software. Been there, worn that tee shirt. I might just order three mpgs to demonstrate that.
    Ironically, and tangential to this thread, my wired pendant (I don’t trust Wireless) appears susceptible to electrical noise now... if I walk it to my machine, the little led “tx” indicator will flicker from time to time as an unsolicited command gets sent. I’ve had it randomly turn the spindle on, and separately commands a Z-Ptobe. Maybe I need to try a wireless one! Or finish this dammed pendant.
    I've just recently built a machine and fit UCR201 wireless pendant and must say I'm massively impressed with it, so much so I ordered 6 more to keep in stock.
    Like you, I don't or didn't, trust wireless until I used the UCR201. At first, I was reluctant to provide it but the customer wanted a pendant and didn't want wires, so I reluctantly fit it with a Big warning of "On your head be it".
    But this wasn't enough for me and I wanted to prove if it was stable or not so I set out to affectively break or trip it up. So the first test which usually blows wireless devices and most sensitive electrical devices is to fire up the TIG welder next to it.? Nope, didn't bat an eyelid. Next was the Plasma cutter and MIg welder, the same result.
    The acid test was when I walked to the other end of my unit, approx 40mtr's, into my office, shut the door, and controlled the machine looking through my office window while my son was welding next to the machine with a MIG welder.
    Nothing I did made this thing wobble and we even controlled the machine from outside the building. I'd recommend the UCR201 to anyone using UCCNC.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. 2nd gen Cube for parts/spares
    By calida in forum Marketplace Discussion
    Last Post: 09-03-2016, 05:06 PM
  2. Hand Ergometer
    Last Post: 11-08-2013, 05:55 PM
  3. 75 mm HAND WHEEL
    By Lee Roberts in forum Programmers Corner
    Last Post: 19-03-2012, 02:58 PM
  4. NEW MEMBER: want buy new or second hand cnc
    By buildwood in forum New Member Introductions
    Last Post: 20-10-2011, 05:36 PM
  5. NEW MEMBER: second hand machine
    By steve r in forum New Member Introductions
    Last Post: 18-11-2009, 09:00 PM
