Thread: New with a threading problem
Do you mean the tolerances for the wire gauges? if so then you need to measure them to at least three (or five) times better than the tolerances of the thing you're measuring. (it's important that the wires are exactly the same size - i.e. to within 0.00002")
As to the thread diameter tolerances for a given fit, is this of any help (they list A & B fit)?
http://mdmetric.com/tech/thddat7.htm
25-11-2009 #2
Hi Guys,
I solved the problem. After further investigation I found what the thread tolerance was as far as minimum pitch diameter. I didn't want to just "make it fit" as that is not the correct way to turn a thread. For those of you who do not know...thread wires are a series of wires in sets of three of different diameters for measuring different thread pitches. Best wire size is calculated for a particular thread pitch. A micrometer reading is made over the thread wires and the pitch diameter (where the wires contact the thread) is calculated from that measurement. Of course this does not resolve the possibility of incorrect or variable feed rates over the length of the thread but is still the best way (other than thread ring gages) of measuring an od thread.
Thanks for your input..
Geoff:dance:
02-12-2009 #3
Just a little tip. Don't try and hold the wires in place with one hand and measure with the other ( unless you have got more than the usual number of digits). Push the thread wires through a rubber band this will hold them in place.
The Following User Says Thank You to Peter Griffin For This Useful Post:
WANTED: Boxford Threading Dial
By Raymond in forum Items WantedReplies: 5Last Post: 07-06-2014, 01:37 PM -
threading ground bar ends
By dazza in forum Metalwork DiscussionReplies: 39Last Post: 11-02-2014, 11:41 PM -
RFQ: M39x4 Threading of MT3 Blank End Arbor
By Jan Rune in forum Projects, Jobs & RequestsReplies: 1Last Post: 19-06-2013, 10:50 AM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
