Thread: Denford easimill help
Hi Colin
The machine came with a control problem but the motors are the original Denford.
The drives are a Gecko G540 which will be great if it is okay.
The power supply is to lower-rated and the VFD appears to be okay.
I will re-wire and see where we are.
It was a tight fit in my garage which is shares with my classic TVR Griff.
Greg
16-01-2021 #2
Hi Greg,
Your mill is about 40 years old, i changed the drive motor bearings in my easiturn3 £50, the other bearings (i found Buck and Hickman cheapest) are metric and cheap as chips. Lube the ballscrews, they will be dry and the lubricator or pipework may not work. I read where the spindle drive was not so reliable and expensive to fix, so if it works it works if not stick it in the bin. It also takes up quite a bit of space and i prefer high voltages covered up. I saw an Easitun 3 nearby for sale a while ago and should have bought it but i was looking at Bridgeports at the time.
Colin
CONVERSION: Denford Easimill restoration and upgrades
By Jonathan in forum Denford MillsReplies: 7Last Post: 12-12-2020, 01:47 PM -
FOR SALE: Denford Triac with ATC, upgraded to USB by Denford
By CNC555 in forum Items For SaleReplies: 0Last Post: 15-08-2019, 02:16 PM -
FOR SALE: Denford Triac PC inc Denford table plus chucks, and Denford CD software etc
By Piero franchi in forum Items For SaleReplies: 8Last Post: 14-02-2017, 04:47 PM -
FOR SALE: Denford Triac + Denford Orac + other stuff
By Clive S in forum Items For SaleReplies: 6Last Post: 06-02-2017, 11:47 PM -
WANTED: Denford Triac / Easimill
By steve1465 in forum Items WantedReplies: 1Last Post: 15-07-2012, 06:40 PM
