Thread: LED lighting panels
Yeah I thought it was the power supply and ordered a replacement. But actually it's the panel that has failed. I can describe the design and failure in more detail (I'm an electronics guy), but ultimately the panel and PSU combinations I have (supplied as pairs) clearly have a design problem. So I have resigned myself to replacing them. That's why I'm looking for recommendations for reliable ones. These ones I have come from the eBay seller 'strictlylamps'. Yeah, I can probably get replacements from them, but I would like to stop messing about with the panels and actually use my workshop for its intended purpose :)
So, does anyone have panels that have been good for more than a year?
Alan
20-01-2021 #2
Well for anyone following along in future, I took one panel apart:
The leds are arranged in two strings, one on each side, each string 7 off x 14 parallel LEDs. Each string of 14 is in one contiguous section. The forward voltage of the LEDs is ~2.5V, and the driver says 1.15A (I didn't actually measure it). So actually the voltage drop will be ~14x2.5V = 35V, the power drawn by each LED about 2.5 * 1.15 / 14 = 205mW. There are 14x14=196 LEDs total so 196x0.205 = 40.25 watts total. That's all assuming the power supply is delivering what it claims on the can.
A bunch of the individual LEDs had failed - about 10 on one side and 20 on the other. When 14 LEDs in a segment fail, then the panel doesn't light at all.
I suspect the failure mode is either low quality or over-driven LEDs. Once one fails in a 14-segment string, then the remaining 13 will split the increased current/power. Then they probably pop one by one, until all in a segment are bust and the panel goes dark. That could be the cause of the 1 Hz flashing death rattle. I didn't have the time to muck about further with this, but my current theory is that low temperature spell recently caused some drivers to deliver too much current. I could be wrong.
I've just ordered replacement branded Philips panels from CP Lighting item # 911401899780 at £30 a go - about 40% more than the previous supplier. Hopefully Philips test them better, time will tell.
RFQ: laser cut acrylic panels
By mnewsholme in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-06-2019, 12:46 PM -
How to get panels into VCarve Pro 7.5
By calibanman in forum VectricReplies: 28Last Post: 11-09-2014, 01:33 AM -
RFQ: Gantry side panels
By fvfdrums in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 03:50 PM -
RFQ: Panels cut from soft plywood
By Rockeyes in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-04-2013, 04:38 AM -
RFQ: MDF Panels (+ More)
By codytom in forum Projects, Jobs & RequestsReplies: 6Last Post: 09-04-2013, 09:16 PM
