    Tom's Avatar
    Lives in Nottingham, United Kingdom. Last Activity: 11-11-2023 Has been a member for 9-10 years. Has a total post count of 176. Referred 1 members to the community.
    Hi Kev,
    Looks good so far - should be nice and rigid with those large alu sections.
    You have an interesting concept with the Z reaching to cut below the frame, do you have any sketches?
    Next you need to decide where to put your y axis gantries, and how to mount your leadscrews and steppers.
    When does your college project finish - a deadline is healthy! I wish CNCs were around when I was at college! :) (actually they were, but you fed code to them on punched card, not usb keys!)
    Keep it up and keep us posted!
  2. Welcome Kev...
    Rather than insert your pictures inline using the IMG tags, attach them using the 'manage attachments' button below the edit box... this will put thumbnails in the post and will auto-enlarge them on mouseover.
    kev's Avatar
    Location unknown. Last Activity: 12-11-2010 Has been a member for 9-10 years. Has a total post count of 20. Received thanks 1 times, giving thanks to others 0 times.
    Quote Originally Posted by Tom View Post
    yea its pretty solid, bit of a pain using the connectors tho.
    with the z axis i got the idea from here
    basically its going to be used for sign making but if i want to put something tall inside it then i can raise the machine up on a stand im going to make, thats why im planning on having no obstructions in the cutting area.
    i will post up some autocad drawings that i have made so far tomorrow.
    with the y axis im thinking of using some more rail, perhaps mounted on the top and bottom of another piece of alu box section. or perhaps top and side.
    My deadline is around june time.
    kev's Avatar
    right just made some stuff up on autocad,
    im not sure how heavy the z axis will be tho as it uses a lot of 10mm plate.
    Any thoughts?
    thanks
Name:	cnc side 1.JPG
ID:	1193   Click image for larger version.
  5. Quote Originally Posted by kev View Post
    Any thoughts?
    thanks
    thats easy... work out the total surface area of the 10mm plate used in square millimetres (just work it for each piece then add them all together), multiply the result by the plate thickness (10) and multiply by 0.00275 will give the weight in kg. (weight of aluminium is 2750kg per cubic metre)
    Hi Kev.
    just 1 observation. Are you only using one rail on the y axis? if so then the 250mm travel + the distance to the rail + the length of the cutting tool will put quite a bit of force on it!
    Good luck with the build.
    kev's Avatar
    Hi Kev.
    hi, no i was thinking of using one rail on the top and one one of the bottom, tho im going to redesign the z axis so that the motor is not so high up, possibly mount it on the other side of the alu profile, offset the weight a bit. im also thinking of keeping the linear bearings fixed and letting the rails move up and down on the z axis instead, this should keep 250mm of 12mm aluminium sheet fairly rigid.
    Its hard designing things , might just order lots of bits and make it up as i go haha
    Sorry didnt notice the label tag was dog legged through the lower one.
    Good idea to fix the blocks and let the rails move up and down on the z axis. Are they 4 way equal loading? Thats how I'm going to do it on mine. I would allow for a least a 1/3 of the rail to be held in the blocks. So for a 250mm travel you would need 375mm rails.
    If its just for sign making then do you need so much travel? Why dont you just use the stand idea but have different size collars to rise it up in increments. Some people have also used multiple mounting heights on the z axis plate to allow for the cutting tool, might be worth looking at.
    Yes but isnt that the fun part.
  1. Replies: 0
