    kev's Avatar
    Location unknown. Last Activity: 12-11-2010 Has been a member for 9-10 years. Has a total post count of 20. Received thanks 1 times, giving thanks to others 0 times.
    Sorry didnt notice the label tag was dog legged through the lower one.
    Good idea to fix the blocks and let the rails move up and down on the z axis. Are they 4 way equal loading? Thats how I'm going to do it on mine. I would allow for a least a 1/3 of the rail to be held in the blocks. So for a 250mm travel you would need 375mm rails.
    If its just for sign making then do you need so much travel? Why dont you just use the stand idea but have different size collars to rise it up in increments. Some people have also used multiple mounting heights on the z axis plate to allow for the cutting tool, might be worth looking at.
    Yes but isnt that the fun part.
    Yes i think the bearings are 4 way equal loading, they are adjustable as well, theres a close up picture of one in my gallery.
    It is supposed to be for sign making and would actually only require about 10mm of z travel but i want to cut big things inside of it lol, i might not go for 250mm of z travel i think i will test it first, see how much flex there is.
    I have ordered some 45x45mm box section and some more rails so i think i might try the make it up approach until i come up with some good ideas.
    I know what you mean about just making it up, its so much easier when its there in front of you, than sitting at a computer with CAD. Have you seen the design guide for the blocks? looks like you will have to be careful with the spacing as any racking will cause them to bind.
    Since they are 4 way loading have you considered putting the x axis rails on their side, that way you just need a flat plate to bolt the carrages to the y axis rail.
    Where do you get the ali sections from?
    kev's Avatar
    Yea i have seen there website, i think you are suppossed to use one block without the side bearings, hopefully it should work ok though.
    I have thought about putting the rails on the side but then there will only be one contact patch per block instead of 2, but putting them on the side would give me a bigger y axis. il see how it goes.
    the alu profile is from RS
    kev's Avatar
    quick update,
    i have put the rails on the side, and its made everything alot easier,
    i have made a design on autocad and started to roughly make it out of steel, as you can see not many holes line up lol.
    im currently waiting for some 45x45 alu profile and the plan is to have two vertical sections bolted onto the alu side plates then, two long pieces across forming the y axis. im also planning on mounting the y axis motor on the inside and using a pulley to attach to the screw that will go down the middle of the y axis.
ID:	1202   Click image for larger version.
ID:	1203   Click image for larger version.
ID:	1204   Click image for larger version.
ID:	1205   Click image for larger version.
    Looking good. with regard to the rails being on their side with only one contact then in dosnt matter as in reallity you are only supporting the weight of the y and z axis. The plunge of the z axis will counter some this and you will then have max strength (4 contacts) in the sideways movement of the x axis where you need it to counter the cutting forces.
    Not sure it I would have moved the y axis rails as well tho. For that long travel on the z you need them as far appart as poss to reduce the moment, the other side effect is that the y rail has moved the spindle futher way! You might want to shift the y axis rail back a bit further to compensate, dosnt mater if the motor overhangs a bit. mind it would be easy the remake the side plates later if it dose cause any problems. (Chatter, binding etc.)
    Did you find RS the cheapest for the aluminium sections?
    kev's Avatar
    i put the y axis rails on the front as it keeps them a meter long and is alot easier to mount a plate straight on, instead of building a box around.
    plus i may be using some low height rails instead, about 9mm instead of 30mm.
    but ye i might have to move the y axis further over the rear bearing.
    as regards to RS being cheapest? probably not but my work always gets stuff from there so its easy, i think it was about 20 quid per section,
    the rails and bearings are cheaper than igus tho,
    kev's Avatar
    i got the 45x45 alu profile today, so i made the y axis, its rock solid with no flex, but i think the igus bearings may have to go as it barely moves on the x axis, so i may have to get some proper ball bearing carriages for the x axis and use the igus bearings on the y axis.
    does anyone know where to get cheap rails and carriages?
  1. Replies: 0
