  1. #13
    kev's Avatar
    Location unknown. Last Activity: 12-11-2010 Has been a member for 9-10 years. Has a total post count of 20. Received thanks 1 times, giving thanks to others 0 times.
    quick update,
    i have put the rails on the side, and its made everything alot easier,
    i have made a design on autocad and started to roughly make it out of steel, as you can see not many holes line up lol.
    im currently waiting for some 45x45 alu profile and the plan is to have two vertical sections bolted onto the alu side plates then, two long pieces across forming the y axis. im also planning on mounting the y axis motor on the inside and using a pulley to attach to the screw that will go down the middle of the y axis.
ID:	1202   Click image for larger version.
ID:	1203   Click image for larger version.
ID:	1204   Click image for larger version.
ID:	1205   Click image for larger version.
  1. Replies: 0
