Thread: First CNC machine
07-12-2009 #2
Now theres a question, theres a lot of "what ifs" and whats it "gunna do" The two main considerations are power and shaft run out. Which leads to bigger size and cost......
I would have thought you'd be ok with a good quality router above 1200W
I had the same problem setting the ways on my lathe and x-y table, after a bit of practice it got easier. The biggest killer was the fiction caused to remove the backlash in the leadscrew. So from now on I will only use bearing rails and ballscrews.I have sort of fallen out with the igus bearings haha, the difference between them being sort of moving and locking up was half a screw turn on one of the carriages.
Hows the rest of the machine going?
07-12-2009 #3
Tbh iv not done anything lately, im just waiting for the rails and bearing carriages,
then im gonna try and get the X axis moving freely, probably redesign the side plates by moving the y axis frame further back over the rear bearings, then i can concentrate on the y axis and z axis, or maybe get some screws on the x axis first.
im just hoping the igus bearings will work ok on the y axis, but probably not haha.
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM
