Thread: RE Hi Everyone. Which cnc to Buy
Welcome to the forum Phil. The budget you have quoted should get you a nice machine. There is a guy on here that builds them to order (Dean Jazzcnc) I think there are a few vids on here somewhere of his machines.
The water cooled spindles are much quieter than the air cooled. One of the cons for the air-cooled are that the fan slows down with the speed and therefore does not cool the spindle...Clive
22-01-2021 #2
Unless you get an air cooled spindle with an extra fan built on top something like this
https://www.ebay.at/itm/253928489328
Andrew
22-01-2021 #3
Hi Phil,
I sent you my details in reply to your PM.
Regards the Spindle then it depends on the quality of the Air cooled spindle, the better ones are fine and very little difference between Air or Water cooled in terms of performance. Though my preference is watercooled because the duty cycle is virtually unlimited, so if you cut large 3D jobs that can take days not hours it does make a difference. The other difference is that you can often buy large Kw rated Air cooled spindles much cheaper than large Kw water cooled spindles.
The cheaper Air cooled spindles however have low duty cycles and poor fans so they quickly get hot and eventually die.! . . Avoid like Covid.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
