Thread: Programming an engraver
I have a Gravograf engraver whose controler has broken leaving only the power unit and stepper motors. I have written a program in VB net to read an HPGL file (of the design I want to engrave) and send pulses to the machine. Works a treat with Windows 98. With Windows XP the machine makes horible noises 'cos XP does not normally run in Hard Real Time. Can anybody help me to overcome my problem?
Best regards
Patch
24-11-2009 #2
You'll probably hate this, since you've already done so much work but..
Have a look at EMC2 running under linux to control your machine. Use a hpgl to G code converter (or start with a DXF file and convert to G code which may be easier).
24-11-2009 #3
laser cutter/engraver rebuild build log
By gavztheouch in forum Laser Machines & BuildingReplies: 37Last Post: 10-11-2015, 05:37 PM -
I will have a trial for programming job
By hoezap in forum Tool & Tooling TechnologyReplies: 7Last Post: 09-02-2013, 03:00 PM -
NEW MEMBER: Fanuc Macro programming
By curly3456 in forum New Member IntroductionsReplies: 0Last Post: 02-02-2012, 10:20 PM -
Spring loaded drag engraver
By Sharx in forum Tool & Tooling TechnologyReplies: 1Last Post: 16-02-2011, 11:10 PM -
Programming Mach3 screens
By Smiler in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 17-01-2009, 03:15 AM
