If you have a spindle that can only be driven by step/dir, and the Pokeys57CNCdb25 can only output PWM, it's not rocket science to convert PWM to step/dir if that floats your boat. I'd start with an Arduino nano and a bit of hand cranked sw. Not for everyone and maybe a bit Heath Robinson, but it saves capital expenditure.
26-01-2021 #2
If I was a good bit younger, I might be tempted - I've just had a Covid jab, so that will give you a ball park idea of my age. :-)
The Seig machines were marketed as turnkey and that's why I got one - so that I avoided the hassle of getting my hands dirty with having to delve under the hood to get things working. And up till now that has worked for me, and I was hoping for a "plug and play" product to do the conversion from parallel port to USB or Ethernet.
I'll probably give another product a go to see if I get a quick solution, but if not, I will probably have to resort to doing what you suggest to avoid this KX1 becoming a boat anchor - in excellent nick. :-)
Jim.
Looking for parallel port cable
By eurikain in forum Computer HardwareReplies: 3Last Post: 20-02-2016, 01:51 AM -
CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
By Greeny in forum Control Hardware & SystemsReplies: 20Last Post: 14-11-2013, 11:59 PM -
parallel port address
By Dan Brown in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 07-01-2010, 12:04 PM -
Which USB parallel port emulator is the best
By bruce_miranda in forum General ElectronicsReplies: 1Last Post: 18-09-2008, 03:38 PM
