    I'd go UC400ETH. Runs Mach3, Mach4 or UCCNC if you fancied a change.
    Or buy a used dell with pport, load XP on it, and away you go. That's what I did for my mill. (but I already had retail discs XP from 2005 so not an issue for me).
    JimG's Avatar
    Lives in Bristol, United Kingdom. Last Activity: 09-12-2025 Has been a member for 9-10 years. Has a total post count of 6.
    Quote Originally Posted by dazp1976 View Post
    I finally went for an ESS installation and that has worked well and it installed with pretty well no problems. I had already gone through the second hand Dell route a few years ago and it was this computer that had given up the ghost. I thought that the supply of old parallel port PCs would probably dry up and thought it was about time I moved on to something that would work with up-to-date PCs.
    Jim.
    Quote Originally Posted by JimG View Post
    Jim.
    Fair enough. I've got my eye on a UC300eth, 2*UCBB boards, UCCNC, and a load of cabling now you've said that.
    I don't need it but, I want it!
  1. Looking for parallel port cable
    By eurikain in forum Computer Hardware
    Last Post: 20-02-2016, 01:51 AM
  2. CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
    By Greeny in forum Control Hardware & Systems
    Last Post: 14-11-2013, 11:59 PM
  3. parallel port address
    By Dan Brown in forum Artsoft Mach (3 & 4)
    Last Post: 07-01-2010, 12:04 PM
  4. Which USB parallel port emulator is the best
    By bruce_miranda in forum General Electronics
    Last Post: 18-09-2008, 03:38 PM
