hanermo2, Cheers
The z axis ratios are way wrong -- as others have said.
So if you have 600 height you should have 300-400 mm width and depth for best results, and not less than about 250-300 in each dimension. - Column Width at present is 270, Y to the furthest point of the gusset from the face of the column is 190mm
Itīs dirt cheap , relatively.
All modern machines use similar methods with large sections and relatively thin walls around 10 mm.
I think I'm a but stuck with this as i already have the surface plate. I thought as the column was off an SX3 and i was using two size to side it would be far stiffer in the Y axis then the gusset plates would help the Y. I will change the gussets as advised by Jazz and may put some in the x axis but I've run out of depth in Y to stiffen it up any more, i don't want to move the column forward as i will loose Y travel.
What would the consensus be, move column forward and loose travel but stiffen the Y or not?
BUILD LOG: El Beast - Initial design phase, comments and critique welcomed!
By Zeeflyboy in forum DIY Router Build LogsReplies: 413Last Post: 30-12-2022, 08:49 PM -
BUILD LOG: First Build-Steel Gantry CNC - Comments on design wanted
By olaff in forum DIY Router Build LogsReplies: 13Last Post: 06-12-2015, 08:34 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
BUILD LOG: My First Attempt Of A CNC
By AdCNC in forum DIY Router Build LogsReplies: 61Last Post: 21-10-2010, 03:55 PM -
help please with first attempt
By phill05 in forum Machine DiscussionReplies: 13Last Post: 01-06-2010, 05:42 PM
