    Another quick question on the pc you are using (and Doddy is making useful inputs on the BoB side so these are parallel lines of enquiry!) - are you using a laptop or desktop machine?
    Laptops can be problematic with Mach3 and use of the parallel port. For one thing, laptop processors have a habit of electronically saying, "hang on a minute - I'm just going to do a bit of internal housekeeping." This might only be for a few tens of milliseconds and as a user you would never notice it but it completely screws Mach3's internal timing. The other issue is that later PCs and especially laptops only supply 3.3V on the parallel port, not 5V as older systems would provide. Both these are good reasons for using an external motion controller which offloads the time-critical bits of the processing and provide cleaner and more reliable signals to the outside world.
    As a follow-up - how are you powering your BOB? Does it have its own PSU - plug-in charger-like device? - or running off a USB port? Using the latter can also give issues.
    Trouble with your kind of question is that part of the fault-finding process can sound very critical but without knowing a lot of what might seem irrelevant details it's difficult to understand what's sitting in front of you - just blame the bloke you got it from!
    Oh and one other thing - i believe i have to post at least 10 times before i can post pictures, but i am trying to think of ten things to say so i can upload them
    Dump the parallel port along with the BOB and invest in an AXBB-E, you won't regret it, it will transform the machine and user experience.
    You can use either Mach3 or UCCNC with the AXBB-E but I strongly recommend you go with UCCNC as it's fully supported by the people who actually manufacture the controller.
    Because of this, it's much more in tune with the hardware and updated when any major changes occur. In real-world use, the motion is much smoother than mach3 and in reliability terms, it's rock-solid stable which mach3 certainly isn't and never will be. It's also much cheaper than Mach3.!
    If you do decide to go with AXBB-E or UCCNC then get in touch as I keep these in stock for machines I build and I'm happy to supply them to forum members.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. SOLD: Hobbymat MD65 mini lathe and BF65 mini mill
    By Boyan Silyavski in forum Items For Sale
    Last Post: 03-11-2018, 12:45 PM
  2. equivalent of HAAS mini mill 2
    By pnub93 in forum Machine Discussion
    Last Post: 10-02-2018, 02:19 PM
  3. Mini 5 axis cnc mill
    By andy_con in forum Machine Discussion
    Last Post: 16-12-2015, 09:46 PM
  4. eBay: SX2 Mini-Mill - Complete Setup.
    By grunt-will in forum Items On eBay UK
    Last Post: 30-01-2014, 08:28 PM
  5. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
