Thread: my cnc
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by SPIKE View Post
    hi guys i really hope you can help me with this one.
    i keep on trying to mill a sign or an 3d object but i keep having the same issue when ever i select my home position on my material this being wood when i load the file in to universal gcode sender pus run or send my machine starts running and mooving to its first position as it should but every time it plunges deep as far as it can go in to the wood it cant moove because of how deep its gone and burns the wood , no matter what i do it happens all the time so HEELLLLP! please
    Due to covid19 the crystal ball has lost it sheen.
    So how about giving some specs about the machine, what controller and the top few lines of the gcode.
    It would also help with a couple of pics would be nice as well
    Thanks for your reply.
    i use fusion 360 cam software then i send the g-code to universal g-code sender i also have candle controller which cam with my grbl cnc diy 3018 pro router laser machine.
    Here are 2 images of my setup you can clearly see the plunge and burn mark from where it tries to travel along the x axis. Click image for larger version.
Name:	My CNC 2.jpg
ID:	29466 i seem to have some issues let me know what you need and i will try to end it anoother way
    All the best Colin
    Hereis part of the gcode
    (1001)
    (T3 D=3. CR=2.5 - ZMIN=-15.249 - BULLNOSE END MILL)
    G21
    G40
    G49
    G80
    G90
    (WHEN USING FUSION 360 FOR PERSONAL USE, THE FEEDRATE OF)
    (RAPID MOVES IS REDUCED TO MATCH THE FEEDRATE OF CUTTING)
    (MOVES, WHICH CAN INCREASE MACHINING TIME. UNRESTRICTED RAPID)
    (MOVES ARE AVAILABLE WITH A FUSION 360 SUBSCRIPTION.)
    (POCKET1)
    M5
    T3 M6
    S10000 M3
    G54
    G0 B0. C0.
    G17
    G0 X46.236 Y22.824 Z12.
    G94 G1 Z3.289 F250.
    S750
    G2 X45.08 Y23.508 Z3.039 R0.95
    X45.764 Y24.664 Z2.789 R0.95
    X46.92 Y23.981 Z2.539 R0.95
    X46.236 Y22.824 Z2.289 R0.95
    X45.08 Y23.508 Z2.039 R0.95
    X45.764 Y24.664 Z1.789 R0.95
    X46.92 Y23.981 Z1.539 R0.95
    X46.236 Y22.824 Z1.289 R0.95
    X45.08 Y23.508 Z1.039 R0.95
    X45.764 Y24.664 Z0.789 R0.95
    X46.92 Y23.981 Z0.539 R0.95
    X46.236 Y22.824 Z0.289 R0.95
    X45.08 Y23.508 Z0.039 R0.95
    X45.764 Y24.664 Z-0.211 R0.95
    X46.92 Y23.981 Z-0.461 R0.95
    X46.236 Y22.824 Z-0.711 R0.95
    X46. Y22.794 Z-0.751 R0.95
    S10000
    G1 X2.023 F500.
    X2.022
    X1.981 Y22.795
    X1.98
    X1.939 Y22.797
    X1.937 Y22.798
    X1.896 Y22.801
    X1.895
    X1.853 Y22.805
    X1.852 Y22.806
    X1.811 Y22.811
    X1.81
    X1.768 Y22.818
    X1.767
    X1.726 Y22.826
    X1.724 Y22.827
    X1.683 Y22.836
    X1.682
    X1.641 Y22.847
    X1.639
    X1.598 Y22.859
    X1.597 Y22.86
    X1.556 Y22.873
    X1.555
    X1.537 Y22.879
    X1.536 Y22.88
    X1.513 Y22.888
    X1.512
    X1.471 Y22.904
    X1.469 Y22.905
    X1.43 Y22.922
    X1.428
    X1.386 Y22.942
    X1.384 Y22.943
    X1.343 Y22.963
    X1.342 Y22.964
    X1.301 Y22.986
    X1.299 Y22.987
    X1.265 Y23.007
    X1.264
    X1.258 Y23.011
    X1.257 Y23.012
    X1.215 Y23.038
    X1.214
    X1.198 Y23.049
    X1.197 Y23.05
    X1.173 Y23.066
    X1.172 Y23.067
    X1.138 Y23.092
    X1.137
    X1.13 Y23.098
    X1.129
    X1.088 Y23.131
    X1.087 Y23.132
    X1.083 Y23.134
    Y23.135
    X1.045 Y23.167
    X1.044 Y23.168
    X1.034 Y23.177
    X1.033 Y23.178
    X1.003 Y23.206
    X1.002
    X0.988 Y23.219
    X0.987 Y23.22
    X0.96 Y23.248
    X0.959
    X0.946 Y23.262
    X0.945 Y23.263
    X0.917 Y23.293
    Y23.294
    X0.907 Y23.304
    Y23.305
    X0.875 Y23.343
    X0.874
    X0.871 Y23.347
    Y23.348
    X0.838 Y23.39
    X0.837
    X0.832 Y23.397
    Y23.398
    X0.807 Y23.432
    X0.806 Y23.433
    X0.79 Y23.457
    X0.789 Y23.458
    X0.778 Y23.475
    Y23.476
    X0.751 Y23.517
    Y23.518
    X0.747 Y23.524
    Y23.525
    X0.727 Y23.56
    X0.726 Y23.561
    X0.705 Y23.6
    X0.704 Y23.601
    X0.682 Y23.645
    Y23.646
    X0.663 Y23.687
    X0.662 Y23.688
    X0.645 Y23.73
    X0.644 Y23.731
    X0.628 Y23.772
    Y23.773
    X0.619 Y23.796
    Y23.797
    X0.613 Y23.815
    Y23.816
    X0.599 Y23.857
    Y23.859
    X0.587 Y23.9
    Y23.901
    X0.577 Y23.939
    Y23.94
    X0.567 Y23.985
    X0.566 Y23.986
    X0.558 Y24.027
    Y24.029
    X0.551 Y24.07
    Y24.071
    X0.545 Y24.112
    Y24.114
    X0.541 Y24.155
    Y24.156
    X0.537 Y24.198
    Y24.199
    X0.535 Y24.24
    Y24.242
    X0.534 Y24.283
    Y24.284
    Y154.716
    Y154.717
    X0.535 Y154.758
    Y154.76
    X0.537 Y154.801
    Y154.802
    X0.541 Y154.844
    Y154.845
    X0.545 Y154.886
    Y154.888
    X0.551 Y154.929
    Y154.93
    X0.558 Y154.971
    Y154.973
    X0.566 Y155.014
    X0.567 Y155.015
    X0.576 Y155.056
    Y155.058
    X0.587 Y155.099
    Y155.1
    X0.599 Y155.141
    Y155.143
    X0.613 Y155.184
    Y155.185
    X0.619 Y155.203
    Y155.204
    X0.628 Y155.227
    Y155.228
    X0.644 Y155.269
    X0.645 Y155.27
    X0.662 Y155.31
    Y155.312
    X0.682 Y155.354
    Y155.355
    X0.703 Y155.397
    X0.704 Y155.398
    X0.726 Y155.439
    X0.727 Y155.441
    X0.747 Y155.475
    Y155.476
    X0.751 Y155.482
    Y155.483
    X0.778 Y155.524
    Y155.525
    X0.789 Y155.542
    X0.79 Y155.543
    X0.806 Y155.567
    X0.807 Y155.568
    X0.832 Y155.602
    Y155.603
    X0.837 Y155.61
    X0.838
    X0.871 Y155.652
    Y155.653
    X0.874 Y155.657
    X0.875
    X0.907 Y155.695
    Y155.696
    X0.917 Y155.706
    Y155.707
    X0.945 Y155.737
    X0.946 Y155.738
    X0.959 Y155.752
    X0.96
    X0.987 Y155.78
    X0.988 Y155.781
    X1.002 Y155.794
    X1.003
    X1.033 Y155.822
    X1.034 Y155.823
    X1.044 Y155.832
    X1.045 Y155.833
    X1.083 Y155.865
    Y155.866
    X1.087 Y155.868
    X1.088 Y155.869
    X1.129 Y155.902
    X1.13
    X1.137 Y155.908
    X1.138
    X1.172 Y155.933
    X1.173 Y155.934
    X1.197 Y155.95
    X1.198 Y155.951
    X1.214 Y155.962
    X1.215
    X1.257 Y155.988
    X1.258 Y155.989
    X1.264 Y155.993
    X1.265
    X1.299 Y156.013
    X1.301 Y156.014
    X1.34 Y156.035
    X1.341 Y156.036
    X1.384 Y156.057
    X1.386 Y156.058
    X1.427 Y156.077
    X1.428 Y156.078
    X1.469 Y156.095
    X1.471 Y156.096
    X1.512 Y156.112
    X1.513
    X1.536 Y156.12
    X1.537 Y156.121
    X1.555 Y156.127
    X1.556
    X1.597 Y156.14
    X1.598 Y156.141
    X1.639 Y156.153
    X1.641
    X1.679 Y156.163
    X1.68
    X1.724 Y156.173
    X1.726 Y156.174
    X1.767 Y156.182
    X1.768
    X1.81 Y156.189
    X1.811
    X1.852 Y156.194
    X1.853 Y156.195
    X1.895 Y156.199
    X1.896
    X1.937 Y156.202
    X1.939 Y156.203
    X1.98 Y156.205
    X1.981
    X2.022 Y156.206
    X2.023
    X89.977
    X89.978
    X90.019 Y156.205
    X90.02
    X90.061 Y156.203
    X90.063 Y156.202
    X90.104 Y156.199
    X90.105
    X90.147 Y156.195
    X90.148 Y156.194
    X90.189 Y156.189
    X90.19
    X90.232 Y156.182
    X90.233
    X90.274 Y156.174
    X90.276 Y156.173
    X90.317 Y156.164
    X90.318
    X90.359 Y156.153
    X90.361
    X90.402 Y156.141
    X90.403 Y156.14
    X90.444 Y156.127
    X90.445
    X90.463 Y156.121
    X90.464 Y156.12
    X90.487 Y156.112
    X90.488
    X90.529 Y156.096
    X90.531 Y156.095
    X90.57 Y156.078
    X90.572
    X90.614 Y156.058
    X90.616 Y156.057
    X90.657 Y156.037
    X90.658 Y156.036
    X90.699 Y156.014
    X90.701 Y156.013
    X90.735 Y155.993
    X90.736
    X90.742 Y155.989
    Here are 2 images of my setup you can clearly see the plunge and burn mark from where it tries to travel along the x axis. Click image for larger version. Name: My CNC 2.jpg Views: 2 Size: 165.7 KB ID: 29466 i seem to have some issues let me know what you need and i will try to end it anoother way
    All the best Colin
    (1001)
    G21
    G40
    G49
    G80
    G90
    (POCKET1)
    M5
    T3 M6
    S10000 M3
    G54
    G0 B0. C0.
    G17
    G94 G1 Z3.289 F250.
    S750
    S10000
    G1 X2.023 F500.
    X2.022
    X1.981 Y22.795
    X1.98
    X1.939 Y22.797
    X1.937 Y22.798
    X1.896 Y22.801
    X1.895
    X1.853 Y22.805
    X1.852 Y22.806
    X1.811 Y22.811
    X1.81
    X1.768 Y22.818
    X1.767
    X1.726 Y22.826
    X1.724 Y22.827
    X1.683 Y22.836
    X1.682
    X1.641 Y22.847
    X1.639
    X1.598 Y22.859
    X1.597 Y22.86
    X1.556 Y22.873
    X1.555
    X1.537 Y22.879
    X1.536 Y22.88
    X1.513 Y22.888
    X1.512
    X1.471 Y22.904
    X1.469 Y22.905
    X1.43 Y22.922
    X1.428
    X1.386 Y22.942
    X1.384 Y22.943
    X1.343 Y22.963
    X1.342 Y22.964
    X1.301 Y22.986
    X1.299 Y22.987
    X1.265 Y23.007
    X1.264
    X1.258 Y23.011
    X1.257 Y23.012
    X1.215 Y23.038
    X1.214
    X1.198 Y23.049
    X1.197 Y23.05
    X1.173 Y23.066
    X1.172 Y23.067
    X1.138 Y23.092
    X1.137
    X1.13 Y23.098
    X1.129
    X1.088 Y23.131
    X1.087 Y23.132
    X1.083 Y23.134
    Y23.135
    X1.045 Y23.167
    X1.044 Y23.168
    X1.034 Y23.177
    X1.033 Y23.178
    X1.003 Y23.206
    X1.002
    X0.988 Y23.219
    X0.987 Y23.22
    X0.96 Y23.248
    X0.959
    X0.946 Y23.262
    X0.945 Y23.263
    X0.917 Y23.293
    Y23.294
    X0.907 Y23.304
    Y23.305
    X0.875 Y23.343
    X0.874
    X0.871 Y23.347
    Y23.348
    X0.838 Y23.39
    X0.837
    X0.832 Y23.397
    Y23.398
    X0.807 Y23.432
    X0.806 Y23.433
    X0.79 Y23.457
    X0.789 Y23.458
    X0.778 Y23.475
    Y23.476
    X0.751 Y23.517
    Y23.518
    X0.747 Y23.524
    Y23.525
    X0.727 Y23.56
    X0.726 Y23.561
    X0.705 Y23.6
    X0.704 Y23.601
    X0.682 Y23.645
    Y23.646
    X0.663 Y23.687
    X0.662 Y23.688
    X0.645 Y23.73
    X0.644 Y23.731
    X0.628 Y23.772
    Y23.773
    X0.619 Y23.796
    Y23.797
    X0.613 Y23.815
    Y23.816
    X0.599 Y23.857
    Y23.859
    X0.587 Y23.9
    Y23.901
    X0.577 Y23.939
    Y23.94
    X0.567 Y23.985
    X0.566 Y23.986
    X0.558 Y24.027
    Y24.029
    X0.551 Y24.07
    Y24.071
    X0.545 Y24.112
    Y24.114
    X0.541 Y24.155
    Y24.156
    X0.537 Y24.198
    Y24.199
    X0.535 Y24.24
    Y24.242
    X0.534 Y24.283
    Y24.284
    Y154.716
    Y154.717
    X0.535 Y154.758
    Y154.76
    X0.537 Y154.801
    Y154.802
    X0.541 Y154.844
    Y154.845
    X0.545 Y154.886
    Y154.888
    X0.551 Y154.929
    Y154.93
    X0.558 Y154.971
    Y154.973
    X0.566 Y155.014
    X0.567 Y155.015
    X0.576 Y155.056
    Y155.058
    X0.587 Y155.099
    Y155.1
    X0.599 Y155.141
    Y155.143
    X0.613 Y155.184
    Y155.185
    X0.619 Y155.203
    Y155.204
    X0.628 Y155.227
    Y155.228
    X0.644 Y155.269
    X0.645 Y155.27
    X0.662 Y155.31
    Y155.312
    X0.682 Y155.354
    Y155.355
    X0.703 Y155.397
    X0.704 Y155.398
    X0.726 Y155.439
    X0.727 Y155.441
    X0.747 Y155.475
    Y155.476
    X0.751 Y155.482
    Y155.483
    X0.778 Y155.524
    Ok
    Where and how do you touch off the part ie. at the bottom or the top and are you doing the same in fusion360 you generally touch off at the top off the part and that should be Z0.
    Also when you jog the Z axis down dose the DRO go more -ve or +ve ie. generally the Z should go -ve when going down.
    I have never used grbl.
    Also in the code you are using a ball nose cutter for a pocket you should be using an endmill . This is nothing to do with your problem though
